just went out to the car on my break, bearings are good. so im thinking its my frozen caliper/needing an alignment
dont know what happened when we replaced the struts and lowered it yesterday but ive got a bad "rub" now all the time and its especially felt under braking. its almost like a bad wheel bearing but the bearings were replaced within the last year. any ideas what it could be?
lowered mine Saturday and had the same noise. My dust shields around the rear rotors where pulled on during removal of the strut. After being bent out a bit they were rubbing the inside of the rotor and making a god-awful noise. I used a screw driver and pushed it back in a bit and problem solved
Snapped a pic with my phone on my lunch break. Did some recoloring
Currently giving a shot at disabling auto AC on defrost modes
and plasti-dipping my center console and cup holder
will do the rear valence tomorrow!
Good stuff, I did that last year following the guide on this site and it worked-out great. The A/C really doesn't need to be running all the time on defrost mode, in my experience you only need maybe 30 seconds of A/C every few minutes to get rid of condensation on cold, humid days.
yea exactly, but still.
it works wonders
I also received my team pro5 vinyl sticker today!
(calis qui vente j'hahi sa!)
it works wonders
Ugh, I've been inside all day, hopefully it dies down when I leave school tonight...
Anyway, my A/C has finally stopped working on fan speed 3 (I used to flicker last summer). When it gets nicer out I plan to fix that properly, I have an idea for a very simple circuit which will permanently fix the problem :)
How did you check your bearings?
got one front wheel in the air, put it in 1st, and listened. then repeated for other side. how i diagnosed the bad bearing in the first place when it really was bad. no noise from the front, its from the back. prob from that frozen caliper
Yea ive seen that speed2/3 fan is a major problem with most protege5's
mine works flawlessly O.o
Finally got my Tokico Kit put on Check out before and after. Now it doesn't ride like a boat anymore.
Before:
After:
Ohh and I need my my fender resprayed badly!!!
