Removed my mud flaps. They just weren't working out for me. Even though they are functional here in Colorado, they had to go.
found out where my leak is coming from. should I just replace the gasket between the two pipes and put on new hardware, or get an obx header since that portion of the jpipe is looking very tired
header....new mid pipe and rb exhaust
it would be a new magnaflow catted midpipe if i replace it. gonna do just the header first though and see where it all stands. something is rattling with the midpipe and its not the heatshield around the cat, it something within.
question with the obx header, do you still put both O2 sensors into it since there is the one above the upper cat and one right below it?
2 O2 sensors lower one has the non fouler done to it
Carolina Mazdas meet March 17th, 2012.
There with Civickilla03 (Kevin), Justanothermp5 (Simon), SCMP3 (Mike), bthai (Billy), and many more.
That's Simon on the right taking "real" photos vs this crappy cellphone panorama
Picked up Megan Racing Springs and Monroe struts from bthai
I need whatever bolt/bracket goes on here on the side that tightens the ac/powesteering belt somehow that come loose and i lost it :/
anyone got a one lmk! thanks
u only picked up the fronts?
Today I should get the following parts..
FMIC
Hard Pipes
Down Pipe
Exhaust System
Drive shaft
505 Intake Manifold
they are sitting on top of the bottoms. Apparently the front struts are blown and the rears are good. My front struts are fine and I think my rears are leaking but I'm not sure how bad. I will see about the possibility of mixing shocks...at least until I can buy new ones all around.
u can mix them. my struts in the front are new tokico hp's. my rears are oem tokicos. im glad i replaced the fronts because it rides so much better
