that looks like it will work but you will need to fab up some extra pipe to go from that three bolt flange to the j pipe
Yeah, it'll work. It's clocked right. I'm aware I'd have to fab that up. I can do all that at the shop. We were trying to come up with a way to make the downpipe ourselves at the shop, but everything we came up with would have been ugly and probably not flow too well. I figure I can get that downpipe and if, for some reason, it doesn't work I'll just sell it to one of the 5,000 240sx owners I know. The 240sx is the new Honda Civic...
If you get the "casting only" of the PEP DP, what exactly is it. What I'm thinking it is, is a solid piece that doesn't have anything done to it, just to "mold" off of it. Am I correct, or could I utilize the actual piece on my car? HELP?!
EDIT: Obviously you guys can see that I'm trying to decide what I want to do for a DP. I'd really like to fabricate something, but utilize the S13 DP. However, if the POPE DP casting can actually be utilized on the vehicle, that'd be a better option. Any input from those that may have fabricated there own, let me know and point me in the direction of your "how-to" thread...
I got the fully loaded with the flex/flange option.
Stealth has just the pope casting piece. He then had a shop help custom fab the rest
I did before I got the pope dp... by the time I hacked enough to get the angle right away from the block and clear the ac bracket I pretty much only had the flange and about 1/3 of the 90 bend before welding in a tighter bend leading out. It was a b**** and most wouldn't have the patience to make this work. Didn't take pics since it was so frankensteined but didn't leak and after exhaust wrap it did the job and almost looked pretty :)
Has anyone tried an S13 2.75" GT25 downpipe for a custom setup?
+1 and it was cheaper then just a downpipe from the pope. Grant it I paid a little less for it then what he is selling it for on his site. I paid roughly 350-400 for a 3" downpipe, 3" catless midpipe with gaskets INSTALLED.
WHAT is the casting piece exactly?
2007 CX7 Rotor:
Detailed Description
Overall Height: 1.90"
Overall Diameter: 11.64"
Bolt/Holes: 5
Bolt Circle Diameter: 4.50"
Center Hole Diameter: 2.84"
Nominal Thickness: 1.10"
Discard Thickness: 1.02"
Type: Vented
2007 MS6 Rotor:
Overall Height: 1.91"
Overall Diameter: 11.77"
Bolt/Holes: 5
Nominal Thickness: .98"
Discard Thickness: .91"
Type: Vented
Is it absurd to consider that the calipers might be interchangeable on these 2 vehicles based off their rotor dimensions?
I told you because the same happened to me. I bought a O2 sensor and connector.
found the culprit. My primary o2 connector melted because it started slightly rubbing against the MAM manifold since the damn o2 bung is on the side. A little bit of metal is exposed which probably shorted it out. Also found a blown fuse which according to the diagram on the manual is for the ECU. So, looks like Im about to buy a new o2 sensor and a fuse. Bad thing is the sensor connector is melted to the connector for the rest of the harness.
