03 msp parts sale
EVERYTHING ON THIS THREAD IS SOLD SORRY TO ALL THE PPL THAT I COULDN'T GET BACK TO ASAP..... http://s1262.photobucket.com/albums/ii607/udontknwfrmfun/all items do not include shipping , if any questions PM me please .... for local atl only (since oil cant be shipped) 15.00 per gallon of mobil 1 and castrol synthetic**
bulbs 20.00*****
trunk plastic 20.00***
radio stuff 10.00******
protege badge* 5.00***
radiator / i.c. / fans****** 100.00***
mass air flow sensor** 40.00****
stock intercooler**** 45.00******
upper lower radiator hoses 20.00***
bpv*** 10.00**********
s/j pipes/turbo / exhaust mani...*** 475.00*
** s/j pipe / cats*** 75.00****
a/c compressor*** 30.00***
glove box / extras*** 25.00**
rear seats msp****** 50.00***
stock struts all 4*** 180.00*
new water pump*** 25.00**
new dayco belt***** 10.00***
coolant recovery tank*** 10.00*
intercooler hoses**** 20.00 (all)***
front and rear rotors*** 60.00****
powersteering pump and tank**** 30.00***
pressure plate and flywheel**** 30.00******
ecu non flased******** 150.00*******
all four calipers w/hoses********* 175.00*******
water outlet****** 5.00****
starter*********** 25.00*****
coils and wires****** 20.00*****
upper and lower intake manifold**** 75.00****
throotle body********* 35.00*****
strut brace********* 50.00******
grill*********** 25.00********
center hand rest**** 50.00***
3 gauge pod and wire loom***** 45.00***
mounts all 3***** 20.00******
dash cover passenger side**** 10.00*****
door moldings****** 40.00***********
instrument cluster cover**** 15.00*********
Items sold :
Door sills - zhyInstrument
cluster cover. - bizTurbo (only). -
SbkillzWater pump. - turbogixxer928Mass air flow sensor
- junya1985protege emblem -
spicymspvt19rear calipers (only)* - Datboibriam18
strut brace/s.brace mounts - msp2fast
center console - speedracer79
gauge pod - Cmezz331
radio braket - kitkit201
bpv, i.c. pipes, radiator & fan assembly , ecu ----whiteMPR05
will the mazdaspeed grille fit on a p5? I know there is a difference between es sedans and p5s. If it will work how much shipped to 92833?
interested in silver center peice of center console - both fans only - and coolant reservoir? how much all and shipped to 77008? ups ground.
Dibs on the calipers. If they were all working okay when you pulled them off, of course.
PM sent.
do you still have the a/c compressor? Looking for all 4 window black plastic window sills,
Got the bracket that mounts to the trans/upper, and goes to the driver's side framerail mount? Not the mount with the rubber isolator - just the piece that mounts to the trans itself (black steel bracket).
