The kit was from Speed Circuit, I have an eBay FMIC so my setup is unique which is why it doesn't fit. The fans barely clear the hot pipe. I still have the stock DP so I dont need a straight neck kit yet, I will probably get a spacer for it though.
I could run the fans on the front of the rad. if they fit between the AC condenser.
I started the car before I went to work and it sounded great with the new catless J/Mid pipe. But when I got back there was coolant all over the floor. Turns out the machine shop that drilled and tapped the bolt hole for the thermostat housing accidentally took a chunk of metal out around the rim the thermostat seals on. I put a bunch of silicone gasket maker all around the thermostat and in the gouge and reinstalled it. Hopefully when I fill the coolant in the morning it won't leak.
