Installed new tune last night. 15 degrees and spun through 4 gears. Was interesting.
i used to do that, get some wide shoes and youll be set
i only spin 1st and 2nd now. but on winters i can chirp 5th
Sounds like a porn star name.Custom LexTune.
Is that a misfire?Damn p0401
So when I drive the MS3 in the rain and don't use the brakes for a period of time, like on the highway for example, when I go to stop I have to push the brake pedal to the floor. Or, I can push the brakes for a second and re-apply them and they will function like normal.
It's almost like there is a layer of water that is getting on the rotors that needs to be cleared off or the pressure from the water is causing the calipers to retract more. Granted, I'm at 86k and am probably due for some new pads but I just find it strange that this only happens in the wet.
Anyone else experience this?
P0401 is faulty/clogged EGR valve, I think.... Some cars just have bad luck with it. Mine's one of them, I've had to clean it 4 or 5 times now
well, i think because seafoam is advertised as a carbon deposit cleaning product that exhaust elements do benefit from its use
i used 1/3 of it in the crankcase once about 100 miles before i changed the oil once, that is supposed to clean up and gummed fuel and/or oil in the lube system, i may do that again next oil change
The induction method gets the most benefit because of the whole direct injection thingy. technically the only thing that passes over the intake valves is air, but since oily vapors and such can go through the intake system via pcv and egr the only way to clean the valves is by an inductiin cleaning method. in normal ported fuel injection the gasoline can help rinse things away
every so often i take the tmic off to clean and inspect the fins, and the inside has been ever so slightly slick from oil vapors. A catch can would help but im just not gonna do that
Installed my AutoTech internals and Forge BPV last night. I'm seeing 1800-1900 psi now.![]()
I typically use seafoam via the induction method twice a year, if nothing else, it entertains the neighbors. I think a catch can is on my short list of things to do...i've seen pictures of the stuff that comes out of them -- nasty! I've not had any EGR problems, but i've got less than 28K on my 08.5 so it may be a matter of time/miles.
