NXS manual boost controller installed... Here we go 10psi. Bye-bye block... :(
Why don't you try 9 and be less scared?
f*ck 9, go big or go home. on a flatbed that is
How many pounds?
16ishhhh and yeah i actually drove about 2 miles home on it like that. was making a hell of a racket. the piston was slapping the crank. no damage to the crank or cylinder luckily thou
it bent along the other axis as well
No sir. My car is set up perfect now. Just gotta go to NC for a dyno tune and my car is done for a while. Only thing left is intake and head work, but that's coming at the end of the year, then I'm going for the stock block record. Maybe switch to an HKS GT25 eventually.
Is the stock block record still 277??? I plan on breaking that soon. Shooting for 300whp stock block. Just ordered a big turbo set up,.getting a bigger meth nozzle, and tuning for corn gas.
that maybe the case on his car. put the gt28 fully spools before 4k rpms and it has a way better punch over what comes in a msp. gt28 on 14psi is amazing and the way it feels is even better
Everyone who is complaining of the "speed bump" noise- On both my P5 and the MSP when it did this, it was the front sway bar bushings. I've gone through two sets in the MSP in 20k miles. First squeak, replaced bushings and it was gone. Second time I got the squeak, replaced the bushings and it was gone. Also, make sure to apply silicone (dielectric grease) to them before installing it.
I agree, I didn't have a problem with my P5 but new poly swaybar bushings over a year ago have worked without any squeaking unless it's very cold. I used Marine grease though, it lasts longer.
