How does 7am sound for you?
I'm not familiar with the ECU, but sounds like you need to do some logging when that happens and modify the tune
Problem with that is I can't find the cable needed to connect to an OG palm pilot (not a palm os, an original palm pilot) and the ecu
The link doesn't put out obdII codes either
The boys wake up at 8:00. Let's do it then if that's cool![]()
Do I still have to bring a cheesecake?
Can't data log hooked up to a laptop?Not programable by palm, but that's how you data log, then you plug In the keypad and make changes.
But no, that's not the connector/wire needed. But thanks for looking
Its his birthday and hes letting you use his garage..... quit trying to get out of it (headshake
Yes, but i would still need the seriallink adapter, which i can't find anywhere
that's the easy part, i need serial to ecu
nada
I'm trying to find someone who has one that
can't find anything online for diagrams
