CorkSport Mazdaspeed Protege Skid Tray
to do an oil change you'd have to remove it ?
What type of aluminum is it , worrying about if it might corrode after a long winter or two ?
Whats the actual weight of it ?
Will it clear AWR oil pan (height wise) ?
The rear brace should be fine, you would have to sandwich the skid tray between the subframe and the brace. The front arm bar is most likely a no go but we have not had a car in with the bar in so we are not 100% either way.
-Derrick
Hey Derrick, I've got a front lower arm bar on my car. I could come by 2 weekends from now if you want. Let me know.
You do not have to remove it to do an oil change. We left enough clearance to get to the drain and the filter.
The skid tray is made from 5052. We went with it because of its superior formability as well as its ability to withstand metal fatigue and stress cracks.
The skid tray weighs 10.5 lbs
We are looking into the clearance on the AWR oil pans.
-Derrick
My frown said something about this. I want but can't afford. Please give for Xmas present anyone?
awaiting for the clearance on the oil pans and front lower tie bar! if everything is good! im sold!
^ Same here ;).................I have both if a test fit is needed :)
Rob
We have a forum member who has the lower brace and it local to us which we will be looking at his car in the next couple of weeks.
-Derrick
The final fitment verdict is as follows
Good News:
AWR oil pan is ok
Front tie brace, between the front control arms fits.
Bad News:
The skid tray will not fit with an aftermarket ladder brace which bolts to the back of the subframe.
-Derrick
