Maiello169
- Mazda, Protege, Speed
How can I bypass my coolant from my turbo ... Notice you guys were talking about that, is it an easy thing to do, or a 3 hr project ..?
did you buy OEM? is it the correct PSI?
Would this be a decent BOV ? : http://www.ebay.com/itm/Universal-H...ff-Valve-JDM-ALL-Turbocharged-S-/390364649190
Thanks , what did you use for fittings ?i used fittings and hose from home depot to make a coolant looop. 3/8" is the hose size.
Okay so its one that I would need to bring to the shop to.get welded on. Once I get my other gauge in and order the new BOV ill have my shop do the gauges and BOV all in one trip, so in the next few weeks . Need to get that coolant bypassed first I think... And need to get more couplers so I can put the FMI on also ... The list gets longer and longer.. thing my front driver side suspsention is going to, squeeks when ever u go over speed bumps ...
So i pressure tested my coolant system and it only holds 7 psi (shop manual says its supposed to be 17.8psi) . (Cue sad trumpets). There was one hose loose but once i fixed it i couldnt find one single hiss or spurt. So im guessing its going somewhere! Im gonna tackle the water pump tommorow cause maybe someway somehow its causing all of this.
oh yea and when i went to start it to run to autozone it started the first time with no stumble and isnt smoking now. WHAT THE HELL TONYS MAZDASPEED?!?!?! its not helping me troubleshoot at all.
