PrinceValorum
- 95 626 FS, 89 Toyota Derux 4x4
^Fo sho
Iirc the PGT guys use the BG non-powered rack. I can't say with any certainty. I looked into it, also, but the ratio isn't as tight to give you more mechanical advantage so you can turn the wheel, which means the tires turn less for the same amount of steering input if that makes sense.
