Got a new j pipe put on today, old one was absolutely rusted out and flange was broke off connecting to catalytic convertor.
Jeez man. Won't that be #3? Does this mean you're selling your hood? It'd probably look awful on a white P5, let me do you a favour and take it off your hands :)
last night, installed vbrace and trailing arms.
today, went and had the alignment checked and nothing had moved and had the exhaust adjusted so it stop banging the vbrace arm.
Replaced pass axle, alternator, and opened up the trans to fix the reverse issue. Now I have one leaky axle seal and my reverse lights won't turn off.
Also tried fitting my fds with 225-50-16 tires. Gonna def need those 3mm spacers
washed it here are the results
<a href="http://www.flickr.com/photos/43150552@N02/6038488963/" title="IMG_0607 by dtoodaloofoo, on Flickr"><img src="http://farm7.static.flickr.com/6090/6038488963_88949995eb.jpg" width="500" height="333" alt="IMG_0607"></a>
8mm work for ya?
We will see. They are on, but it started pouring 10 minutes after, so I have not driven yet. Will probably go out later today to see how the stability is, then check the lug nuts. But so far, everything seems ok. The appearance difference is very subtle. I took before and after pictures.
Thank you for the great quality and nice packing. :)
Went back to the stock injectors, then put back and old map then did some small changes. Still having a hard time adjusting my BOV.
Also washed it. Its been about a month. My workplace has lot of dust due to construction. lol
Just walking out the door to change the front left caliper (seized). Do I only have to bleed that one brake? IIRC its closest to the MC. I dunno for sure though. Also painted the valve cover wrinkle black. Just have to sand the paint off the lettering. Gonna go get some non-foulers and finally put on the Ractive header thats been sitting in my closet for 6 months... maybe tomorrow. Debating painting that with some black header paint as well.
