Hey SCMP3, how do you like your ksport coilovers? I just got a set used and I'm curious how they ride. I also need to buy a replacement shock, so if you know a place that sells them cheaper than ksport's website let me know.
I have a full set that I will sell to you on the cheap that you can salvage and use for parts. One strut is blown and one strut has a bent endlink tab. $175 shipped to your door.
Marine clear gel coat and polyurethane clear coat for weather protection.
Made with pure carbon fiber.
No modification needed to install
Simply slides underneath the weather stripping and is held in with double sided tape or trim adhesive.
that's directly from isports website...i might try to see If it will slip under
pic definitely shows it under the rubber
bought a p5 yesterday from scott, going to swap all parts onto my LX that i can. therefore the lx will be drivable again. it won't be twin charged yet. but i'll be daily driving a badass car! woot!
sweet thanks.....do you think they 3m taped it underneath the rubber along with slipping it under there?
yea, I don't think just slipping it under will hold it down for very long
enough of that find out more about the wb o2 sensor/primary o2 sensor conversion stat lol
haha i'll be tryin it out this weekend when i install my mpi piggyback back onto the car.. but honestly i don't see why it wouldn't work with our ecu.. cuz all it needs is a 0-5v signal for o2 right?? and thats what the white wire on the eugo is for.. so basically you just need to clip the signal wire from primary o2 and wire the white aem wire in its place n thats it.. but i'll try it this weekend.. i got a bunch of wiring to do anyways
Got the Silvia gt25 rebuilt last night. Still have to put the exhaust/compressor houseings on and clock it to where it needs to be
It wasn't to bad. Kinda tedious with all the small pieces but it wasn't to bad. Note that the Silvia gt25 is a journal bearing turbo which equals rebuildable.
It also has a smaller exhaust side which equals quicker spool times ;)
applyed a concealer on my MSP lip for now to cover up the deathly scratches and mishaped look....
