Thanks guys. Do you have to bleed the line or anything like that? I assume that you still run the engine for 5 minutes while spraying seafoam into the line?
Any links to a thread on the proper procedure to do this?
It is becoming more a more common opinion that Seafoam doesn't do much.
if you have the can in your possession already, just follow the directions on the can. deviating from the recommended procedure can sometimes lead to damage.
The spray is better for carberators....you shoukd really use the kind you pour
very simple to pull the brake boost line, use a funnel that fits in it, and pour while a friend keeps the rpms up just enough to keep from stalling
do this when the engine is at operating temp, pour in 1/3 or 1/2 the can slowly (this is where a friend comes in handy to keep the revs up), shut the engine off for about 5-10 minutes, then start back up and rev it up and down several times. Smoke should ensue the area
What is your intent with the seafoam? If you are trying to clean the throttlebody than you have no choice other than to remove what ever you have to in order to access the throttle plate. The spray is good for that if you even need it in the first place.
If you want to top clean your upper cylinders than find a vacuum source closest to them and slowly add it versus allowing the engine vacuum to pull it in quickly. On my engine I use the PCV hose but I am not familiar with the MS3 setup.
I've never had to clean my throttle plate with 87K so far. But I have done a whole lot of seafoam treatments both via the PCV hose and adding to the gas. It works when used frequently. I always use the liquid in the bottle versus the spray. No reason why you could not spray it in to a vacuum source for top cleaning.
http://www.seafoamsales.com/
