check the actual plug and see what it looks like see if there's any oil on it. Could be a number of things clogged injector,bad wire, bad ring on that cylinder. You get the j&s in? if so has it shown any knock?
Yeah, I have the J&S in. It hasn't shown any knock.... only running 9-10 psi atm, have about 6000 miles on the new engine and it has been running great up until today. I'm thinking maybe a clogged injector, since i swapped the stock injectors back in not too long ago. Any way to check for a clogged injector or bad wire?
well for the wire your going to have to pull out a volt meter and see if its grounding out. As far as the injector goes swap it to another cylinder and see if the misfire transfers to that cylinder
Alright, thanks.... headin out to swap injectors.
damn im jelous
man, i have been wanting this manifold for the longest time.. and I finally saw an opportunity so I jumped on it. thought about getting the gt28rs too but it's pending sale to someone else. maybe sticking with the gt30 anyway. I also may be getting some top secret stuff as well from someone else
nice man. you can tell me the top secret stuff... you know i wont tell
