Interesting. The accessory brochure you have is different. My brochure is a print copy of the 2010 CX-9 vehicle, not an accessory guide. Inside it shows all three trim levels in a grid outlining which features are available for each, and which features are optional for each. Fog lamps are listed as only available on the Grand Touring trim showing a "-" under the Sport and Touring levels where "-" is footnoted as "Not available" as an option from the factory or the dealer. That begs the question, if it's not even a dealer installed option, is there something else missing the Grand Touring has that is required? And if not, why wouldn't Mazda make this a dealer option?
Using the OP's individual part numbers takes it over $500 and likely still needs bulbs.
I would recommend that you order the kit and switch online from Tasca Parts online of one of the other online parts house being operated by dealers. The pricing is a bit less. The stock bulbs are definitely way over priced form the dealer and I would go for aftermarket replacements which are brighter.
With regards to the accessory brochure, I downloaded this brochure from the Mazda USA site. The only thing is that you have to remove the bumper covers and the fender guards to get the parts installed. Not hard but it does look a bit time consuming.
For the 2010 CX-9 all models, the accessory part numbers for after factory install are:
Fog light Kit parts no diff from the first post in this thread
TE69-V7-220 (Kit - assemblies for Left and Right side of car)
GSM6-61-122A (switch)
TD11-V7-235A (Light bulbs - dunno if this is one or two) - Again I would go for aftermarket bulbs not factory bulbs as they want too much for them
