Made some (slow) progress today. Got the engine on the stand and start pulling off peripherals. Ended up shearing off one of the lower intake manifold bolts in the front iron. Fortunately there's about 1/2" still sticking out so I may be able to extract it but I don't plan on reusing that part anyway. Onto the pictures...
Engine on stand:
Shot of the "port" side. Notice all the oil buildup. There was something seriously wrong with the front rotor - this thing is nasty.
Here's a picture of the auxilliary port sleeve for the front rotor (far upper right port in the previous picture). Again, note the oil buildup.
Now here's the rear sleeve. Notice how this one is basically spotless but there may be a reason for that. When I tried to turn the actuators the drive the sleeves I could not get the rear to move AT ALL. It doesn't seem like it has moved in a while.
Now some spark plugs. First picture is the front rotor and the second is the rear. It may be hard to see but the plugs for the first rotor are noticeably "wet" while the plugs for the rear rotor are dry.
And finally, some pictures of the specialty tools I'm using. In the picture below we have the pilot bearing puller (top center), pilot bearing and seal installer (top right) and flywheel wrench (giant black bar). That wrench is over two feet long and has a 2-1/8" six-point wrench on one side!
Here's the last trick little piece. A flywheel stopper. This will allow me to remove the flywheel and main pulley bolt without the use of impact tools.
Lastly, for the hell of it, here is the pile of parts I've removed so far and the mess I've made in the garage.
