I also learned how to fix the dull on our roofracks and the window thingies on the bottom of each window (black trim) from its dullness, "Mothers Back To Black" after about a couple washes it'll start to soak into the material and less and less of that solution will be needed each time and it'll stay black and shiny new looking longer after each wash.
Actually just did this on my girlfriend's Charger... the black molding around the windshield was very dull grey, but is back to black now :)
yea dude that stuff actually works and im glad i found out about it. now i shall never have dull trimming EVER AGAIN!
and then my fog lights been out for a while now, so today i went ahead and pulled out the fog and got ready to replace the bulb, and i notice the filament wasnt broken, so i plugged in a working older fob bulb, and i tested the fog and it still wouldnt turn the fog on..so i checked the fuse box right away, fuse was fine no burnt fuse but the legs were all kinda gross looking so i put in a new one, and then i tested it again, still wont work, and i check all the connectiions making sure it was all tight and snug, and even check my wiring for the fog mod, and and relay or little relay box was clicking as it should when you turn on/off the fogs, and it still not working and i have no idea what do check next....any advice?
Went to wire up a Haltech (sprint 500) for a friend. Everything went well except that there were a few things missing that the "support guy" didn't tell him until after we had swapped
everything. (good thing I know how to wire...lol) so wasted 4 hours for
Nothing.
Also gauge pod is almost done. I painted it gloss black but it didn't turn out as I wanted. I'll sand it back down and get some flat black. Also picked up new sway bar bushings for the progress bar. Old bracket ripped off the sub frame...
Energy bushing didn't work. Gotta mod the brackets to fit. So I took off the whole rear sway bar.
i wouldnt use the honda wiper delete, its metal and idk about you, but i dont think metal and glass seal too well together. I used a rubber cork from lowes, hasnt leaked yet and ive had it deleted for over a year now
It is rubber...not metal, and made specifically for this purpose...
Where did you get the wiper delete part from?
you can find them online, the intergra wiper delete for like 10 bucks, Scratchnsnif found it.
Chessir...it is an OEM Integra delete...go to the Honda/Acura dealer...they are $6...
Some can be metal but they are the older ones before the realized the problem.
Noticed I needed rear pads today, also took off (most) of the tint from the tails and noticed a lake in my driver side light. Parking it in the sun for today to see if that helps. Pics to come later. I actually like this look over what it was before.
got my bumper back today. all nice and pretty now! he didnt black out the valence like we originally discussed (he forgot but didnt charge me for it) but thats okay. If i so desire, which i do, ill black it out again myself. and this time, ill take much more time and care into doing so so it wont chip off
i managed to get my front knuckles replaced this weekend! it feels and sounds soooooo much better than before... now to get the timing belt and water pump next week and hopefully a new front end soon
Lewis7789 and I got my motor just about ready to come out. Just got P/S lines, A/C lines, clutch line, axels, and motor mounts!
And here's the STOCK PILE of parts I'm selling...lol
Dropped her off at the shop for the first time in her life :( Just having the brake pads replaced, which I was going to do myself but one of the caliper bolts is seized.
Have pads and lines sitting on the front passenger seat. The pads I know I can do, but I don't know if there is a certain order to do for the lines so I may have a shop do it. Thinking I can tackle all of that tomorrow after I get home from work.
May wait until Wednesday to do all of this or the weekend as my lights from Matt V should be getting in then as well.
Lines are easy....replace one at a time.....get a bleeding kit and have someone keep oil in the resovoir while you bleed.....new brake oil FTW
In addition I'll add that you should go in this order - PR, DR, PF, DF
And run to Autozone and buy a 10mm flare nut wrench. Makes a world of difference when dealing with rusty lines.
ps- Kyle, your P5 in all it's shiny glory makes me happy and cry a little inside mine isn't shiny anymore. Looking good, brotha.
