Sunny Deets
- 2010 Mazda 3
I went to move my 2010 mazda 3 after lunch break at work, in which the car started up fine, drove fine, and unlocked fine, but after moving the car i went to lock it back up and it took an extra push of the button then usual. after that i went to check to make sure it was working ok and the car would not unlock using the key or the keyless remote. I tried holding buttons down turning the key in every way. the trunk will not release nor will the alarm sound. I've read problems with an electrical board corroding and causing the whole system to not unlock. The only key hole thats on the car is on the driver side door as well so i can't even manually open the passenger side or trunk.
I haven't been able to get into my car at all and i need help, if anyone knows a fix to this or if it is just going to be something the dealer has to handle i would appreciate any info back. Thanks in advance
