lizardman743
- 2003 Mazdaspeed Protege
There is a weird hump underneath my carpet in the passenger rear floor board.
Almost thinking its an amp. Should I investigate, or is my suspicion right?
Just lift up the carpet and look.......?
well basically, i had to pull out his dash to locate and fix it. it was running along the passenger side seams. there's a glue type of stuff there, but it was all cracked up. so i re sealed allof it.
just made the appointment for my wheel bearing. pass side is TOASTED.
not gonna attempt it and fail like i did?
^I Failed last Aug. too! I should have just taken it in the first time to get it done right. Instead failed then had to take it in to get it redone.
Well, I wasn't going to go there, but the experiences I've read on here are exactly why I am not even attempting it. $250 to not have to think about it... I can live with.
Hey guys I need help. I want to buy a new set of hub centric rings but need to find the ID and OD of the ring? Is there anyway I can find it on this website so I don't have to take the damn wheel off?
http://www.discounttiredirect.com/direct/wheels/mb_wheels/product/submitProductSize.do?v=008078|2003&pc=53622&typ=Car%2FMinivan&tmn=Weapon
I need helppppp lol
Wow you guys had that much difficulty doing your front wheel bearings? That's crazy. I found it relatively easy when I did mine....
<--Installed an updated speedcircuit engine, trans, new awr engine mounts, and a slew of other stuff. Some of it is top secret for now.![]()
Got my new Forge waste-gate in the mail yesterday, now I just need to find the thread that explains how to install the internal waste-gate with out removing the turbo. Can anyone shoot me the link, I did a search and couldn't find it?
Quick and dirty how-to or how I did it before.
removed all hardware from the exhaust mani to the head, loosen bolt from s-pipe to block bracket, disconnect the j-pipe from the block bracket, pull all forward a inch or two, buy a extra pack of c-clips because you WILL drop it and misplace it, remove WGA nut from under the car(you can get to the top one from the top), put back together.
Edit: im sure im missing a step or two but thats teh gist of it.
That weird hump under my carpet...
was....
A cookbook.
A motherfucking cookbook.
I lol'd, lol'd hard.
it can also be done without pulling the manifold, but its a LOT of jacking around and should only be attempted with ratcheting combo wrenches. I did it without... and I do NOT recommend it
