or just open the valve, push the pedal down all the way, hold it there, and then close the valve, let up on the pedal and then repeat, at least that is what I did, but it takes 2 people.
also, got my brake dust boot thing on finally, but I have been having a lot of trouble getting the piston back in, used a C clamp and tried to pretty much muscle it in there with a lot of pressure, but it didn't budge, I have moved the pistons back before when screwing around with my brakes but they have always had the brake line attached, instead of the piston being completely out, but everything lined up, I even tried to put the piston back in there without the dust boot and no such luck.. it's really getting frustrating,
my next guess would be to connect the brake line and push some brake fluid back into the caliper and then see if I can then push the piston back in.. any suggestions anyone?
