03.5 Blazin yellow MSP partout
Status
Not open for further replies.
u still have the wing!"? Im asking cause i dont see it on the sold list. Or maybe i missed it...
^ huh? Not a bad idea now that you mintion it. Never thought of it like that but it probably wouldn't be from the forum?
I didn't feel like sifting through 29 pages to look...Do you have either/both of the rear calipers (in good working condition-no torn boots, etc)?
Happen to have an FS-DE water neck by chance?
Looks like this, only not snapped in half :(
its a part that bolts to the front of the block.. thermostat would be the other name.
No.
Its the water outlet on the right side of the head, above the transmission. For the upper hose and heater hose return.
The lower hose goes to the thermostat housing adjactent to the turbo.
How'd you snap that thing?
Was putting the car back together after replacing some turbo gaskets and coolant return copper washers. When filling the car with coolant, noticed it dripping on the trans, said "thats odd".
When I pulled the upper hose off, it broke off like wet paper. Looking further into it, the housing was pretty corroded and it ate the aluminum.
Do you have the reverse switch that plugs into the tranny? Kind of looks like a O2 sensor with 2 green wires....Please PM if you do! Thanks
Updated list of parts that have been SOLD:
Side markers, shift knob, washer kit, lower grill, door sills, headlight supports, ecu cover, DF inner wheel plastic cover, egr tube, cup holder(shifter bezel), inside DR door handle, shift boot, Ebrake boot, turbo kit(rad+intercooler, rad brackets, turbo, wga, oil+coolent lines+ oil cooler, exhaust mani+shield, S+J pipe, hot+cold pipes, air box, BPV+hose, MSP ecu, ac condensor), PR door complete, rear strut hats, front A pillars, ENGINE, headlights, RB springs, climate controls, insturment cluster, wheel center caps, coolant reservior, engine harness, glove box cover, fog deletes, msp engine cover, R skirt, hood latch, msp pedals, dual cat, both O2 sensors, dash bezel, rear cross member, bumper cover, pass axle assm, bump stops, spare tire and cover, dipstick, DS jam sill, coilpacks+plug wires, DS rear caliper, DS front caliper, TRANNY, DS door, DS fender, 03.5 LIP, PS rear view mirror, radio bezel, grill, pr seat belt assm, horn, sub brackets, Pass ABS sensor, Driver's side hub and axle, pass window switch bezel, brake booster line, sub encloser kit, fuel pump, fuel pump assembly, dimmer switch, seat covers set, radio pocket
Status
