ok well heres a late update, i installed the maf and filled fluids and everything, went to start the car and not enough battery power, so i charged the battery overnight and tried again in the morning but noticed a puddle of coolant under the car. i searched everywhere and came to the conclusion that its the freeze plug between the engine and tranny. So now the tranny needs to be dropped to get to the plug. what pisses me off the most is that I didnt even install the freeze plugs, it was the machine shop. Lesson learned: never trust someone else's work, always go back and check. Well anyways, I trued starting the car and it will fire and run for maybe 3 seconds then shut back off, even if i give it slight throttle. im thinking it could be the old gas. does anyone know if their is a drain plug for the gas tank? i looked and couldnt find one, so i just put in some fuel additive to see if it would work. any other ideas as to why the car will only run for a few seconds then die?
only good part to this is since I will be dropping the tranny, I will go ahead and install the LSD.
