Thinking about a little 35 squirt eventually...I'm pretty sure that should work fine with an auto.
yea you're better off doing methanol injection setup instead of nitrous. The reason being is that our ecu's don't like nitrous. The spontaneous power is there, but because you're bypassing MAF with nitrous, the ecu doesn't see you spraying, therefore ecu can't adjust right away and hello misfire.ooooo...OK. I guess I'll just stay slow and loud. At least I'll look good! LOL!
ooh i am at about 103k
OK. I'll do some research and check into the Methanol set up.
Thanks!
Omg she's only a baby!
It sounds like I need forced induction (turbo/supercharge) to run an MI kit. Can anyone confirm?
