ok ok lots of noobs in this thread. quick explination
this is a MAF (Mass Air Flow) sensored car. This is the sensor you reuse when you do an intake install or is attached to the OEM airbox. This is probably the most important sensor in the car as it drives nearly everything else..
BOV is VTA (vent to atmosphere) BPV is recirculating.
If your relief valve is upstream (before) the MAF, then you can VTA all day, since the air is lost before the sensor sees it, it doesnt matter
If it is downstream (after) the maf the computer thinks it has X air when it actually has Y
Computer injects corresponding amount of fuel for X air, runs overly rich and the O2 sensors in the exhaust freak out and try to trim it unsucessfully
your car runs like dogs***
you backfire
you clog/damage your cats
backfiring puts extreme axial loading on your turbine, causing premature wear and failure
and all you Gen2 guys need to get a fuel pump before you do any serious modding. Read Cobb's AP notes on their website for further info
http://accessecu.com/support/docs/support/AP-MAZ-002/2010 MS3 Support.pdf
and to the shmuck that said raise boost to compensate....explain to me how raising boost will have any effect on your AFR when you let off to shift and are NOT in boost
