- 03.5 YLW MSP
Question. Turbo oil return gasket. Is the one on th block the same gasket as on the turbo?
NO, The one on the turbo is a o-ring and the one on the block is a normal gasket.
beh.. would i have to get the kit from mazda then?
I didn't use a thread to install mine, just removed the bumper, lined up the lip where i wanted it and clamped it down. marked and drilled the holes put on the bolts and added extra big washers and reinstalled the bumper
What about the turbo side? Seriously? An o ring for hot oil return?
http://www.atpturbo.com/mm5/merchan...tp&Product_Code=GRT-GSK-008&Category_Code=BCS
So would this not work? Tempted to rip all the stock oil an coolant lines and replace with flexible ptfe. Thinking that taking all this s*** off when i need to get to the mani is gonna suck pretty bad.
Went WOT and my afr went below 10.0 and got a p0304 cel. Time to change some plugs and cross some fingers
Thats weird.. mine always falls below 10.0 when I get into boost. It doesn't even need to be in WOT for it to dip that low.
So uhhhh where do i get this oring? Mazda? Or jyst find one that will fit?
Ordered some new front and rear swaybar bushings from the dealer today. I've ordered 2 sets of urethane bushings now and neither of them fit, so **** it I'll just stick with OEM and try to keep them greased regularly during oil changes.
