Droid torque app
Haha I have one too. Just waiting to get my MSP running. Bro got me one too. He uses his on his P5 and works perfect. Can clear codes and all. I was impressed with it. I cant wait to use mine. He's had it for about two months now.
So Replaced thermostat no more over heating.
my friend gave me some good tips.
if your car starts over heating turn your heater on. It will help control the heat it will still be over heating but not to the max. You will also know your pump is working.
the most accurate dyno program for iphone is dynolicious
My brother got dynolicious on his touch, along with the proper mount to use dynolicious. Said my car made 225whp at 6.5-7psi. Oh, and we weighed the car right before to be as accurate as possible.
Yeah. Motor/performance mods are CAI, 3" TBE, SteedSpeed Mani, FMIC, 440's, Alcohol (running pure) Injection, & Microtech. Also other supporting mods, not power related, but I guess they could be calculated into the way the car works and puts down power overall.
Won't really get a chance to check the accuracy of dynolicious though, as I will be installing my MBC and J&S, and upping the boost.
so I moved the AIT back to the cold pipe..
well its 48 outside but in my cold pipe is reading 70
drove around went to autozone need somestuff for my new radiator...
car sat outside for 15 min got back to car started it up the temp was at 90 deg..and you could see timeing is realy retarding on the graph..
final conclusion it seems safer to ride with the ait in cold pipe reading correct temp and adjusting timeing..less chance of timeing to be to advance and air to hot due to heat soak..
so has anyone else tried the app..its been helpful as of late Ive changed my intercooler back to the front mount from the saab. Runs allot cooler its been an average of 10 degrees difference from outside temp to cold pipe temp. Also it has helped me keep track of engine temps what temp does everyones car run at when driving I'm at 181 and fans kick on at 205. I don't like them kicking on so late my fan cant keep up so I have a Question what thread size is the thermostat relay for the electric fans i would like to buy a adjustable so it kicks on at 190 any help would be greatly appreciated.
1st off this APP is awesome, 2nd I'm looking for Mazda PIDs, so I can I can enter them into the APP. Please forgive me if someone has already posted such info.
it is awsome and as far as I know no one has posted anything the only pid I want is knock. I use this app while I drive I have the car temp, intake temp,timeing, mph, and maf signal graphing while i drive. I got alarms set to 115 on the maf which i think is 4.6v.
I have my ait after my intercooler it runs around 10 deg higher then outside air on average. The reason I state this is because I would love to see which intercoolers are more efective for our car this info would be awsome.
