We have the stainless long tube headers and 2.25 exhaust in dyno testing right now. Turbo kit is in beta testing, and the 330mm brakes are done and on the test mule along with the coilover set up
brakes are four wheel disk 330 mm front and 300mm rear
We use the same dyno, MAHA LPS3000 PKWWhat kind of dyno? I ask because you seem to be a touch high baseline. Not that it matters as long as you stay to the same dyno while tuning.
Your correct on the timing but both our test cars are horribly lean until 3800~ then get pretty rich.
Both dyno runs were done on the same dyno(Maha).
With the stock 4.1 fgr I think a revlimit at 7200 would be perfect.
My car had maximum power just 50-100rpm below the revlimit(6500) so the cams should hold good power until 7200.
Check also for a head gasket in order to increase a little bit the stock relativly low compression(only 10:1).
Keep up the good work!We are waiting for the hot stuff!! :Ο)
Still no word from Antoine?sure, contact us, the reflashes are ready and we are very happy with the results!
How is AV status coming?the rev limit on our test car was raised to 7200, but we suggest 7000 unless you do cam /head work.
The stock 2 went from 83whp on our dynapak to 102 with nothing more than the reflash, but the jump in area under the tq curve makes the car sooooo much more fun to drive
