What have you done to your Mazda6 today?
Just got in from a 3 hour record. Took off the PG exhaust manifold. Installed the stocker back. Put back on the brackets and put the tmic back on. Installed the stock TIH and the CPE nano. Also got the battery back in position in the engine bay and hooked up the positive wire. Its gonna feel wierd driving the car now!
Hahahahahahah 100K club :p. Wow that's like 160,000 kms :|... jeez I just hit about 67,000 kms.
Going into winter mode soon, suspension getting jacked the fcuk up, winter blades put on, oil changed and winter tires/rims. With this also comes snow shoots FTW
67K.. jealous... i'm almost at 92 after my little adventures the last two weekends...
can we join the club at 100,000KM or do we have to wait till 100K miles????
i got mine a little sideways tonight... 18" bfg kdws "all seasons" really suck at 0 degrees... but the car loves it... as soon as i can get some hoist time i'll throw my winters on so that the salt doesnt get at my tenzos :(
Lol. Drove my car to classes today. 1000 km till next oil change. Diode trick is still working perfectly. New bob flutters a bit too much for me under light boost. Cruising afr's are a little rich for my blood. As soon as my new copy of atr shows up I will adjust that. Come on Travis!
ok so i musta missed what you recently did zinger... diode trick?
Put a one way valve pretty much in the black line off the secondary o2 sensor. The rectifier diode is used to turn ac current into only one half of the sine wave. So basically you end up with half a wave, it still fluctuates but it does not allow reverse voltage flow. What's the purpous of this? While blocking reverse voltage it also scrubbs off a bit of voltage. By scrubbing off a little voltage it brings the voltage down to a more acceptable level. This sofar has been tricking the ecu into thinking my cat is functioning properly. The diode I used was a little larger then I wanted to use but it was the only size available in my area. I didn't want to have to wait for a smaller one to ship. This might be contributing to my little bit rich cursing afr's. But 14.25 - 14.45 is hardly rich.
Brought the snows up from the basement, wire brushed off the rust, gave 'em a bath, added air, and rattle canned them black again. They go on next weekend I'm thinking :(
Had my all seasons mounted on my spare set of MS6 rims (which I got for 100$ boo-yah). Will put General Exclaims on my new MS6 rims come summer I think. Should be getting my CP-e rear diff mount, mounted soon along with my clutch TSB. Mazda gave me a quote for 400$ to put it on which is a little high, but they are also providing a loaner so might as well just get it all taken care of at the same time.
Finished up my car today. And she is back to life!! Running pretty good too. About to start my FS thread.
tmic ftw!
got my NoDak plates finally. no more sh*tty dealer plates. I wonder how John Q. Law is gonna like my lack of front plate.
As long as it's in the front right on the dash and your tint in the front isn't dark u should be fine, it your tint is dark you'll get a warning then $20 ticket
