Would 195/65/15 tires fit?
I know right now my all-season tires are 195/50/16. From an older car from last winter I have winter tires from an A6 which measure 195/65/15. I was going to be shopping around for 195/55/15s with new 15" rims for the winter.
Thanks for the help!
My guess: yes.
The radius will be about 16mm larger than the stock tire which should still clear the strut perch. I'm not 100% sure that it won't rub on the fender though. I'm sure someone else will be able to give you a definite answer.
you wont have any problems with that size. im running a 205/55r16 and im lowered on eibach springs and i need multiple people in my car going over bumps to rub, and it doesn't even rub that bad. you wont rub at all.
i'm running 195/65 15 kuhmos. they clear the strut by about 3/16" and don't rub. so it'll be close. might want to mount one and check first. speedometer/od error for me is 6.8%
Just trying to understant the 6.8% error, if my speedometer says 50 km/hr that it wil actually be 53 km/hr?
Exactly, in one rotation the larger tire covers more distance than the stock size. So when your odometer says you've traveled 1km, you've actually gone 68m more than that (1.068km).
Hey fellow winterpegger, that is what i'm running as winter's, on steelies,on my 2002 P5. No fitment probs and i'm maybe 1-2% off on speedo.
Nice :)
I've found the most accurate way to determine the speedometer error coefficient is to drive around with a good GPS unit and compare speeds. I think even with the stock tires the speedo will indicate that you're going a bit faster than you are actually going. So you shouldn't use the tire size circumference percent difference to determine your real speed because there's a good chance that the speedo wasn't right to begin with. The percent difference can only give you the relative error between the two tire sizes.
TL;DR: For an accurate idea of how fast you're really going, use a GPS.
