Do you have a parts list for the Oil System..someone told me you did...forget who...what about the stock MSP Oil Cooler, I have heard good things about it...
I heard good things about the stock MSP oil cooler too, but I went with a Setrab. Something is better than nothing.
Heres the list. I will PM it to you too:
oil system parts list:
-WITH DocB Oil Pump and PRV-
oil filter relocation kit ebay item# 330431388141
oil pressure gauge and sending unit ebay item# 270357091470
oil pump ebay item# 130328449925
stainless steel braided lines approx 15 to 20ft ebay item# 230397537751
4 pcs. AN-10 straight flare fitting sumitt racing part# SUM-220090B
4 pcs. AN-10 45 degree flare fitting sumitt racing part# SUM-220086B
2 pcs. AN-10 90 degree flare fitting sumitt racing part# SUM-220087B
oil cooler (Setrab is the best brand for the money) ebay item# 270575771116
FRAM part# PH8A oil filter (AutoZone or WalMart)
AN-3 turbo oil feed line sumitt racing part# EAR-63010148ERL
restrictor pellet ebay item# 220599799353
turbo feed fitting at relocator 1/8' NPT to AN-3 Flare sumitt racing part# AER-FBM2000
AN -10 turbo oil return line (use the left over from PRV)
AN -10 turbo oil return fitting at turbo sumitt racing part# SUM-220086B
AN -10 turbo oil return fitting at oil pan sumitt racing part# SUM-220086B
AN -10 oil pan fitting male weld in bung sumitt racing part# SUM-220062
-WITHOUT DocB system-
tee adapter sumitt racing part# EAR-991701ERL
coupler fitting to adapt tee to engine block sumitt racing part# EAR-991101ERL
turbo feed fitting at tee adapter 1/8' NPT to AN-3 Flare sumitt racing part# AER-FBM2000
Water Feed System
-Including throttle body-
AN-6 braided hose from water neck to turbo top sumitt racing part# SUM-230610 (10 foot length)
AN-6 braided hose from turbo bottom to throttle body inlet
AN-6 braided hose from throttle body outlet back to water neck inlet
4 pcs. 1/2" hose clamp with end RUS-620193
2 pcs. water fitting banjo style at turbo ATP part#ATP-FTG-004
vacuum nipple for turbo wastegate/ boost controller
From ATP turbo:
FTG-QuickTap-CompHSG
Code: ATP-FTG-010
