2011 BMW Alpina B5
mikeyb
Contributor
01 BMW 325xi Touring
What is it?
It's the new Alpina B5 Biturbo, the latest creation from the BMW-based manufacturer and the first chance weve had to sample a 'performance' version of the new 5-series.
Recent Alpinas have avoided using the same engines as M division products, but the B5 will come pretty close to going head to head with the forthcoming M5. It shares the same basic 4.4-litre V8 engine (the inlet set-up is different), equipped with two retuned turbochargers.
In Alpina tune the unit produces a flat 500bhp and 516lb ft. That's enough, says the firm, to take the car from 0-62mph in 4.7sec and onto a gloriously unrestricted 191mph.
Unlike the M5, which is likely to use a dual-clutch transmission, the B5 gets an eight-speed automatic. But the unit has been developed by Alpina and ZF, and it uses a trick way of speeding up shifts when you're in one of the car's sportier modes.
Instead of merely retarding the engine timing, the B5 uses its direct injection tech to merely cut off a cylinder or two. Alpina says the system cuts gearshift times in two, to around 180ms.
What's it like?
Jaw-droppingly fast. We drove the B5 from Alpina's base in Buchloe to the UK - in time for its appearance at the Goodwood Festival of Speed - and with an empty stretch of autobahn in front of it, it's supercar quick.
Alpina's claim of 0-62mph in 4.7sec feels conservative - and as for the top speed, well, we saw an indicated 190mph with three and their luggage aboard, and it was still pulling strongly.
Truth is, though, that making a 5-series with this engine feel strong on a motorway was never going to be the biggest challenge faced by Alpina's engineers. More testing is the task of making it handle on poor surfaces and twisty roads, and here the firm's modifications - lower suspension, non-runflat tyres and comprehensive reprogramming of BMW's adjustable dampers - pays off.
We wouldn't say the B5 has precisely the same level of agility and subtlety as Jaguar's XFR - but it's not far off it at all, and that means it's very good indeed. Revised steering programming makes the wheel feel lighter at low speeds than a 5-series, and weightier when you're pushing on, and it's a more satisfying set-up than BMW's.
With the car in Sport or Sport+ set-up the ride is firm but still compliant (no runflats, remember, just Michelin Pilot Sport 2s, or Pilot Super Sports on the final cars) and body control is excellent.
That trick transmission works well, too; we can't think of many dual-clutch units that beat it on speed and smoothness. The engine has massive urge from beneath 2000rpm, and if you push on it makes a great Nascar-esque soundtrack. It's perfectly docile for everyday use, though; cruise along at 80mph (barely 1900rpm) and it's silent.
Should I buy one?
At around 70k, the B5 will sit above the Jaguar XFR on price, but beat it hands down on exclusivity. Even our car - production prototype number one - was beautifully finished, the spec is relatively generous by BMW standards and Alpina can also offer a personal service matched by no mass manufacturer.
Of course, you could be tempted to wait for the M5, which will offer a more hardcore experience but, almost inevitably, more compromises on ride quality to boot. But if you're more sold on a 5-series than an XF, we'd be sorely tempted to put down a deposit now. Even by Alpina's relatively high standards, this is the firm's most complete package ever.
[autocar]
The stunning ALPINA B5 BITURBO
The Buchloe-based automaker, ALPINA recently revealed their latest B5 model based on the new F10 BMW 5 Series. The B5 enhances the aggressive look of the current 5 Series by offering its own treatment. Similar to what we have seen on the B7, the new B5 offers a blend of luxurious performance, elegant styling, sporty handling and exclusivity.
ALPINA B5 represents an alternative to the BMW M5, but continues to differentiate itself from the M5 with its traditional branded elements, such as the oval four tailpipes or the larger air vents incorporated into the bumper.
Under the hood the B5 carries the current V8 <nobr style="color: darkblue; font-weight: bold; font-family: Arial,Helvetica,sans-serif;" id="itxt_nobr_3_0">engine</nobr> from BMW, which is also used in the ALPINA B7. The engine found in the B5 carries the internal designation N63 and achieves 507 horsepower (373 kW) at a moderate 5,500rpm, with maximum torque of 700Nm from 3,000 to 4,750rpm. The Bi-Turbo appellation refers to the two turbochargers comfortably nestled inside the V shaped 8 cylinder block.
To fully leverage the potential of the engine, ALPINA have optimized the indirect inter-cooling system (air-to-water / water-to-air) with short intake tracts and increased inter-cooler flow. The high-performance cooling package gains its thermo-dynamic efficiency through the use of a large-volume low-temperature
inter-cooler, as well as two water-to-air inter-coolers placed close to the engine.
The pistons are a high-performance variant developed together with Mahle to deal with the extreme temperatures and pressures associated with up to 1.0 bar charging and the engines 9.2:1 nominal compression ratio. Altogether this results in an impressive specific output of 115.3 horsepower (85kW) per liter and a mean total compression of 20.1 bar. Direct injection and Double-VANOS contribute to the B5 Bi-Turbos class-leading performance in terms of emissions and economy in the super saloon segment: 10.8 l/100km (26.2 Imp. mpg) and 252g/km CO2 (Combined as per the ECE Norm).
The powerplant is matted to a modified version of ZFs eight-speed automatic gearbox.
Top speed is set to be limited to 191 mph and the car runs dash in only 4.7 seconds.
BMW should consider marketting the B5 here in the states. I've seen 8 different B7s in the last week.
def do not like that gear change setup...cant remember what its called right now, slipped my mind
but we have a 6 series at school, and i never ever drive that one out of the garage because it has the same type of gear changer, and ive never taken the time to figure it out lol
alpina's are def sick cars though
That is just the sportronic automatic shifter BMW uses in the larger vehicles. It's pretty simple to use.
