I definitely get worse mileage in my MSP than my P5. My p5 with a cracked intake tube still got 26-27 easy. Last tank in my MSP was around 22 but I know it's because of my heavy foot, i'm still getting used to the boost.
So I'm wondering if I can buy an individual wire for the ECU or if I have to buy an entire wiring harness. I am looking for the solid brown wire(pin #64) on the harness that controls the ABS.
I haven't done anything to it today but drive it but tomorrow Im buying a set of cam seals and a valve cover gasket so I can put in this J spec intake cam and CS exhaust cam. By the way, for those that have swapped cams before, what type of lube did you use for the cam lobes and stuff?
I would recommed oil.. seeing as thats what lubes them. are you sure you're not going to have to reshim?
so far, I haven't heard of people reshimming with these cams, everyone that has used them to my knowledge has pretty much just dropped them in with no changes at all.
edit: found the installation instructions on the CS website. It is the assembly lube I was talking about.
so far, I haven't heard of people reshimming with these cams, everyone that has used them to my knowledge has pretty much just dropped them in with no changes at all. and I asked about the lube because I remember reading a how to for swapping cams by alejo nin and he applied some type of white lube to the lobes after installing them
(boom07)
so far, i haven't heard of people reshimming with these cams, everyone that has used them to my knowledge has pretty much just dropped them in with no changes at all.
edit: Found the installation instructions on the cs website. It is the assembly lube i was talking about.
Retrofit my Headlights!
Well it's not right at the pin that my problem lies. The wire is damaged and my dad soldered it but I still think the connection is ******.
and those headlights are sexy!
If your just replacing part of a wire, then just get the same gauge wire, solder and heatshrink it. its not special wire unless theres a fuseable link or its shielded (i think just the 02 wire is shielded).
I was wondering about that too, thanks.
