Wagonbacker9
- 2004 'Hoe
I think the bottom line is that you can't accomplish what you want to accomplish the way you want to do it...
16's are stock on a P5.
17's are stock on an MSP.
Lifting the car on 18's... you could still have some rubbing, but the car will look retarded like that anyway. But there are lots of factors going into the rubbing with 18's. Specifically... offset of the wheels. Several people on here have run 18's on a P5 successfully. One that comes to mind is altspace. He had 18's on his P5 when he had it and they looked awesome.
even if you raise the car, you don't want to put thicker tires on a rim that big. it'll rub when you turn, throw your speedo off, and ruin your fuel economy.
thats MSP stock so its always a good bet, and honestly, I prefer the 225/50/R16 option, but my setup preferencess are geared more toward handling than anything.
new generation... LOL. damn kids.
wat abt spacers, wat are those, i read it on another thread. would tht help
If I were here is what I would do. Sell the 18" rims you have and get some 17" rims, This will alow you to run a tire that has a slightly taller side wall so help give you a smoother ride while still looking sweet. You have to think of tires and wheels like this, Take a quarter and lay it on the table, that represents the diameter of the tire allowed on a given car, now lay a dime on top of that, that's the 16" wheel on the P5, if you replace the dime with a penny that's like going with 17" and if you replace the penny with a nickel that's like going with 18's, remember the whole time the diameter of the quarter never changes. If you just put larger tires on 18's your speedometer is going to be off and not give acuarate speed and there will be rubbing when you turn even on stock suspension. So Get some 17" wheels with 215/45/R17 tires. Then get some better suspension. There's not a lot of info in the progress springs but from what I know they are an appereance spring made for looks and not ride quality or handling at all. Your stock struts/shocks may be blown, I'd get some new Tokico HP "Blues" struts, about $100 peice and then some Eibach Pro-Kit springs. The springs are progressive meaning that they are comfortable for daily driving and not super stiff for a good ride but the spring rate increases as you load the spring when cornering to give you good handeling.
if your offset is too high yes. but i highly doubt you have that problem.
wat abt the weight of the rims, is tht somethng i shud think abt when buying new 17's
1.) struts: stock or tokico? u help me, tht the reason i posted the forum.
2.) how do i see if my wheels are heavy? wats the regular weight.
3.) they are low i just check it says 215/35/18 84Y
4.) stiff sidewalls. i have no idea wat tht means.
thnks for showing some concern. plz help me out through this. people see my car and be like damn! and when they sit in it, bro sell this car, any car rides better than this.
I had the same problem.Now I use stock struts with a 1 inch drop springs and 215 40 18 tires on a p5 and no problem at all.
stock struts don't hold up to being lowered for very long. Trust me.
