Methanol Injection - Injector Location
mspHtown
MSP 2003.5
I was reading through the Steedspeed intake manifold thread and everyone is gung-ho on a direct port meth injection, regardless of their experience or background with the different setups. I figured I would offer my experience (for whatever it's worth) in a new thread instead of cluttering steedspeed's thread.
I used to run a pre-throttle body fuel injection setup using the smt-6 (mpi) tuner. I ran 2 "blue giants," each rated at 440 cc/min and had them spraying into the cold-pipe about a foot from the throttle body. Fuel injection pressures vary, however they are usually set at roughly 43 psi and can build 1 psi for every pound of boost the engine sees. Regardless of differing opinions on this setup, I had zero issues with equal fuel distribution. I checked my plugs countless times and each plug always looked identical to one another. I had no misfires or any other issues. When I broke the engine down for a rebuild, everything was in great shape.
Now consider placing a methanol injector in the cold-pipe (pre-throttle body). These injectors run on a pressure ranging from 150 psi to 250 psi (depending on the quality of pump you are using). I am running at a peak pressure of 200 psi with my labonte motorsports setup. With such high pressures, the methanol/water mixture atomizes so well that distribution will not be an issue. Comparing to the fuel setup, I was having no issues at lower pressure with a fuel injector that was designed to spray into the engine and not a hard-pipe, but it still worked without a hitch. Now consider a meth injector that sprays at a much higher pressure and uses a spray pattern designed to "fog" unlike a fuel injector.
Awhile back, I spoke with Dan at labonte motorsports (I believe he is the owner). We had a discussion about whether I would benefit over a pre-throttle body setup with direct port injection. From his experience, he said that as long as each cylinder is receiving an equal distribution of air (i.e. the manifold is designed properly), then the highly atomized methanol will have equal distribution as well.
Failsafes are another aspect to look at. Consider running 1 meth injector pre-throttle body. I am running a failsafe that requires me to be above a certain methanol threshold (an injection flow rate) in order to run a higher boost pressure than what my wastegate pressure is set at. If I don't inject a certain amount of methanol, I can't boost over waste-gate pressure or damage my engine from a lack of methanol at high boost conditions. Also, if my injector were to clog during a higher boost condition, the failsafe would immediately return me to waste-gate limited pressure. By having 1 injector, the injection of methanol or the lack of injection gives the failsafe easier "interpretation" of whatever rate of injection I am at. Flow rates are dependent on one injector, not 4. 1 injector gives the setup 1 point of failure.
Now consider running 4 meth injectors (1 per cylinder). You now have 3 additional points of failure (4 total). 1 nozzle could clog resulting in a cylinder thinning out and subsequent damage occurring. If you are monitoring a methanol gauge, you will see a drop in the flow rate. Yes the drop will be an indicator, but the drop will be less significant and more difficult to notice. If you are running a failsafe similar to my setup, then that drop off in one injector may not be enough for the system to realize that there is a failure and waste-gate limited boost would not be activated.
Overall, assuming a proper manifold design giving equal air and equal meth/water distribution to each cylinder, a single pre-throttle body injector setup has less points of failure, a much simpler design, allows the failsafe to easily do its job, and has a lot fewer connections (fewer sources of failure).
I have been running a 1 injector pre-throttle body setup and put down ~300whp and ~310 wtq pushing 18 psi on a dynojet. The ambient temperature was 105 degF (texas summer!). Also worth mentioning, my J and S was quiet as a mouse (i.e. no detonation).
I run a pre-throttle body nozzle, and prior to that I considered long and hard a direct port setup. Not worth the extra complication and ugliness in the engine bay.
pre-throttle and pre blow off valve. It seems help alot when you lift the throttle and the water mist condensed simply blow off by the valve.
stfu, tell me whats wrong by doing this. Before I was running post bov and I get some hesitation problem after some hard boost... Now its all fixed up.
before putting BS on post, take a s***, helps your constipation problem.
lol(popcorn)
Haha. It's a total fail. You always put it after the bov.
1) needs to be within 4-6" of the throttle body or you'll lose all atomization before it hits the manifold. Good luck Getting any meth to your engine.
2) bovs aren't meant to get wet, they'll stick open.
3) after letting off and getting back on the gas such as when shifting there is a few seconds when the bov is transitioning from open to closed that
A) you won't have enough airflow to draw the meth into the engine and
B) that all your spray simply goes out the bov. Both of these conditions mean the engine isn't getting any meth.
ive never seen pre blow off valve either, although what maxx says makes sense i dont really know i just have never seen it done that way, so i personally wouldnt run it pre BOV.
WHAT THE ****?
please do a test, find a leaf blower, plug the end to the pipe and put injection on, then check yourself how the mist goes, I dont know where you got your theory that the nozzle MUST be placed 6 inches of throttle body, its not a MUST. Its a suggestion. Anywhere after the intercooler is fine, if you pipe arnt 30 feed long.
BOV stick open? its your bov made of glue? YOu gotta idea how much water vs air pass by valve? **** even after hard run my bov is still dry from the inside.
Please stfu until you tried it yourself and see the result then compare. Theory alone doesnt count.
WHAT THE ****?
Wrong!!! (enguard)
(mswerd)
You obviously have no idea how quickly methanol evaporates (or condenses when mixed with water) or you'd have it within 6" of the throttle body. Just move the nozzle, it's easy to do yourself. Just drill a new hole and plug the old one. In the time you've taken to type why you think your way is superior, you could have moved the nozzle already...
injection is OFF when you lift the throttle, and blow off. who needs injection when its off?
seriously i run WI way longer than most of people here, do what you want to do its your choice.
end of discussion.
(stooges)(bike)(limb)(freak)
Correct!!!
im using pure water. no meth
Lets end the bickering kids, But the facts are this (ask google they even know!)
You use a MIXTURE or Pure Meth, NOT JUST WATER. And you never put it behind the BOV because its not good for it (the BOV) /END THIS DOUCHBAGGERY
But to the OP point... it was a kinda tl;dr moment for me... Can I get a sparknote on it?
Do you strongly agree with direct port in being better then being ~6' away from TB?
