This is for some of the wiring freaks... LIKE ME.
I have a 2006 5, basic sport with A/T & the 6 CD setup. No Nav & no Sat.
I have successfully added some some cool LED lighting in the Cargo area ( I'll have to post that). Now I'm trying to add some up front.
I am looking for a power supply point, in the shifter/ front Cig lighter area, THAT ONLY goes hot when you turn the lights on. IE.. parking or headlamp.
I have attached some lighting already to the leads that connect to the Cig lighter, up front. But that just means that when I turn the key to the full off position, that those wires are not hot.. IE.. can't run down my battery.
I am specifically wanting to hook up a 4 LED floor-board lighting setup, so it will be very low leeching from whatever/ wherever the power source is. If you can name an area and even post a pic that would be much appreciated. With my luck, someone will have a very obvious area.
More minds are better, that's fine with me.
Thanks in advance 5'ers.
PS, the rear LED lighting was so awesome and easy to install. That OEM cargo lighting is a joke on the 06'
