Whoops....I actually meant to say which testpipe works with the MSCBE 80mm or 65mm.
are you referring to the stock cbe on the speed3 or the aftermarket cbe offered by mazdaspeed?
Well. 65mm is 2.55in. and 80mm is 3.1in. I have a 80mm test pipe on my stock cat-back right now.. it'll work just fine just as long as you have the 80mm gasket. It doesn't need to go inside the cat-back, just push it up to there and make sure it's flush and tight and there shouldn't be any leaks. (This is just an "in case" situation the 80mm is too big for you)
Great....thanks guys. 80mm sounds like the verdict. Gonna go with the Corksport.Roger that, I have the same 80 mm setup on the stock CBE and it's leak free.
80mm with stock CBE? So you're putting 3" test pipe on 2.5" exhaust? Sounds counter-productive to me.
