Aggressive fitment anyone?!
here are the rears - way to much offset for the MSP so i'm looking at 18x8.5+30
I used an 8mm spacer to clear the hub in the front, and the adapter/spacer in the back clears the rear hub (idhitit)
are u still gonna try it?
ha ima need coils to pull it off. Probably not till tax min which is gonna be a min. But im def gonna try it. Looks waaay better than I thought it would. Think you could fit a 215 in there?
sooo much poke
agreed for the rear - +22 on the back is way too much offset for my liking so i will not be running +22 in the rear. Just the front. I slapped them on so i could start the measuring process. right now i'm leaning towards +30 in back. it will be some what of a staggered set up. te37's at 8.5 width have few offset options; +22 +30 +40. i don't want to run spacers but if i have to run +40 i may have to.
I just put them on for pictures. The car never rolled with them. Strut clearance is fine after you use spacers.
