Anyone have pics of a CD player relocated to the pocket right above the cupholders and below the ashtray...also a How-to on recovering the door panel fabric...
Pm evade I know he had a deck located where u speak of
pm hkpro5 I know he replaced his door panel fabric
It stretched well, I really want to know if the entire fabric part comes out or not, like on Hondas...I did it on them, but having trouble with this one...fabric didn't have much give though...
Hmm, I was going to re-do mine with micro-suede this summer, but I was assuming the inserts would pop out like on most other cars... I've gotta finish my 2 current projects b4 I start on that, tho.
The foam comes out but its hard to wrap like you are wondering. So what you should do it pull the foam off the door. Use it as a template. cut the fabric. Glue the foam back on, then add the new material. That way you can have the new material cut out and have enough material to tuck without too much or too little.
This is the easiest way. Also when you tuck it. Shove that b**** in the hole.
Also when you get to the upper door part at the edge near the door lock you will have to use extra glue there and you will have to fold it. There is no space to tuck there.
what air horns are you running? im thinking of going to a junk yard and grabbing an old semi's and put in the car
I posted a while back about them... they are just standard cheapo red air horns... i forget who makes them but you can get them at a place like princess auto (although i don't think you guys have that in the states).. They are a lot more high pitched,
im looking for semi sound... heard it on a scion xB years ago and since then ive been looking for something compact enough to be plausible in a car (and since the stock intake is taken out there is more than enough room to fit a compressor large enough to run air tools off of under the hood for a ninja install)
Yea, last night while we were downtown, it was kind of funny because the guy behind me in a Chevy S10 had a semitruck horn.. so loud! much louder than what I have. I'm going to try to find one and install it. And yes, there is a good amount of room for a compressor where the stock intake was, as long as you can find a good way to mount it.
i flipped my msp pocket upside down to put the radio on the bottom
gullwing style now
