Did you own a Honda before, cause urethane lips unpainted definitely reminds me of them, especially when people say what you just said...
Unpainted Lip<Painted Lip...
Check the steering bushings
AWR mounts>all
mazdaspeeder, you still like your side awr and front rr insert set up? im in the car on the highway a lot so i want it to be nice
As in the bushings on the tie rod ends? Not sure it's tie rod ends, as my steering is still tight. I'm going to replace endlinks (with yours, I'll order soon) and sway bar bushings before I go for the MM.
I would (and did) buy AWR mounts. Do it once, do it right.
What do you mean "do it right"? Are you saying the ********** mounts aren't quality? I would say they are just as good if not better in the sense that they are a softer durometer (62).
Sliver5 said:you'll still probably have wheel hop
you guys dotn know how to launch(drive2)
