MP3Night Turbo Build
2-10-10 Oil Temp Gauge (Prosport), Triple Single Din gauge holder, AWR Side engine mounts, Altered Customs Bov Pipe flange.
List update on first page
Parts on the way
23. SS AFC
24.Oil feed line
25. Boost/Vacuum gauge
26. Turbo - oil return fitting
27. Turbo Stud Replacement Kit
28. Vibrant Vacuum Distribution Block Manifold: Black
29. turbo outlet gasket
30. S-pipe -> J-pipe gasket
31. Exhaust manifold -> Head gasket
fittings for the vac block are 1/8" NPT btw so you can start looking for those
1/8" NPT--> 3/8" hose fitting fits brake booster line perfectly, make sure u cut to the intake side of the check valve
how much boost do you plan on running? i use stock heat range at 14psi and i havent had a problem yet
i use NGK copper plugs, they dont last long but there so cheap that it doesnt bother me lol
Just 7psi, Lol alright cool then I'll be fine. I thought for some reason I did.
Nice mp3. I always wanted one back in the days when i had my Protege lx. Looking forward to ur build.
