Can someone help me out
jasbadmp3
mazda,mp3
I just boosted my MP3 and im have some issues when strat to build boost my car start to spit and spuder like it has no gas andf i dont know way can some one help me out i still have stock injectors and feul pump so i dont know if thats the issue or not can some one please give me some info (gah)
definitely get a MSP ecu. u dont want to boost on ur MP3 ecu as it has advanced timing
yeah i have the msp ecu and the ssafcv2 already but im still having this problem and i have talk to some guys that have boosed hondas and srts but its not a mazda
yeah.. u need help from the more knowledgable mazda heads on this forum. it might hhelp if you venture out into the MSP section of this forum too man :)
aren't the mp3/protege injector's less flow than the msp injector's. Maybe not too sure on that?
Make sure your fmic pipe's/couplers aren't loose at all.
Nope, they're the same.
I would make sure you have your MAF oriented properly. What is your total setup? Stock intake manifold? What kinda FMIC? Exhaust? BOV/BPV? Is your MAF on the intake or the cold pipe?
yes im still runnin the stock intake manifold with a cheap fmic i have a custom 2.5 exhaust from turbo back with a hks blow off valve as for the maf it is on the cold pipe off the turbo
Are you running the stock spark plugs in it still? If so are they still gaped to 32+? If so try dropping them down to 28-29 and give that a try.
Stock plugs in the MP3 and stock plugs in the MSP aren't the same. MSP requires a step colder plugs.
Go get yourself some ZFR6F-11 NGK plugs and gap them to .030-.032. I don't think they're the cause of your issues, I have a feeling you're venting the BOV with your MAF on the intake, but you should have the proper plugs in there anyway.
yes im venting my bov but my maf is right off the air intake on the turbo so its turdo,maf,intakepipe,filter and thats it my a/f gauge it telling me that as soon as i hit boost the car drops to lean.like its not geting enough fuel.
Which protege ecu is best to go with when turboing a NA protege? I read msp ecu is best, then i've read p5 ecu is best...
Yea your problem is exactly what I thought it would be. You can't vent if you leave the MAF on the intake cuz the MAF is reading a certain amount of air but a good portion of that is vented, so the ECU never adjusts the amount of fuel and your car stalls.
To fix it you will need to recirculate the air back into the intake (recommended), or if you want to keep venting then move the MAF to the cold pipe after the BOV.
And your lean spot when entering boost is normal, it's a MSP ECU thing. There is really no way around it besides a standalone ECU to replace the MSP one.
Neither are really that good in all honesty. The MSP ECU is better cuz it allows you to use a piggy back such as the SS AFC to get rid of the god awful fuel cut it came programmed with, but you still can't tune around the lean spot at throttle tip-in. The P5 ECU can be used with a o2 sensor voltage clamp and adjustable fuel pressure regulator and it doesn't have lean tip-in issues, but you are VERY limited when it comes to tuning.
I've used both setups and they're about the same. I guess the MSP ECU is better since it allows for the use of piggy backs. The best option is a standalone of course. But for a street driven Protege, the MSP will suffice.
MSP is the ONLY one that will handle boost properly without something like a RRFPR, which is really not a very good solution for fuel management. it will work (auto trans guys don't have any other option really), but you'll never get a GOOD tune.
more to the point though:
I think you need to go through everything and double check your work. plumbing, wiring, vacuume lines, everything. It should not go lean in boost, so theres definitely a problem. venting the BOV after the MAF will not cause your issue. I've run that way, and really the only ill effect is the car will likely stall due to too much fuel if you blow off and then let it fall to idle. It will not cause a lean condition, so something else is definitely going on.
ok well i change the maf location and that didnt fix the problem it alomst acts worst then before. changed to the msp ngk plugs gaped to 30 and still the problem goes on, I also think it may be a vac problem but im pretty sure they are on right any one have a vac diagram they know of. thanks again guys for all you input
you should be pulling 22ish in/hg at idle. if you're not, start there. then check all of your couplers wires and lines, etc.. you have a way more significant problem than plugs or maf location
