There are two clips you must detach that go from the AC unit. One is under the drivers side foot area and the other one is in the passenger foot area. Each cable is connected to a white wheel so you can't miss it. Kind of a PITA the first time you do it but after you do it once you won't forget how to do it.
exactly how does that work? go in from the back with the socket set up or pull the surround a little bit and get at it that way? i gotta paint mine up with my wheel paint and see how it looks. i like a little contrast between the surround and the temp control faces.
Replaced the stock stereo with aftermarket, took all of 5 minutes at best and i didn't have to take any dash apart, that was awesome. guess it makes up for the lesser joy of changing the EGR valve
- if anyone can tell me, what is the vent tube from the EGR valve supposed to connect to?, or is it just supposed to hang in the fender - the directions were sort of cryptic on this, and well pretty much every other step of the operation as well
Andrew2, did you swap door handles too? I want black door handles
nope.. never got around to it.
But there are protege's with black door handles? Sweet
