the stock injectors seat correctly. as you can see.
there are no gaps that show through, they're just gaps on the inside of the runner, which i'm a bit worried. the welds on the outside are fine.hopefully they're good enough to hold it together.
the only logical way i can see the 440s working, is if the plastic orange piece at the base of the 440 is broken off, and the stock 0 ring is used there, that's the only way i see those working with this manifold.
Well ideally I want to use the 440s so if you can make them work do whatcha do. If you dont want to try I will sell the 440s and have to find some larger injectors that will work as drop ins.
And looking at the pictures it does look like those gaps will disrupt the flow and I'm also worried about integrity..
