Cleaned up the ride for Spring and Summer.
Seminole man.........looks good......loving the stance.........what size wheels and tires are you running.......suspension mods?
Thanks Fellas!
@bighoopty
- Suspension consists of Tokico HP Blues with Espelir springs. Total drop is about 1.4 F/R.
-The Enkei's are 17X7.5 +48 with 215-40-17 Yokohama S-Drives. I had to roll the rear fenders ever so slightly to alleviate the minor rubbing I was getting in the rear (no homo.)
@JDMJNKY
- One of the more subtle mods on the car that just made sense. The clear sidemarker lights just didn't fit in well for me.
the other day i took the shifter trim which i painted black and painted it again the graphite to match my wheels. doesnt look too far from the stock silver in the pics, but it is darker.
also managed to get my thule rack on with my civic's fit kit. the pads dont see flat like they should but they sit down pretty well. going to mod the pads thoguh so they dont scratch the roof at all like they did on my civic
and also its not p5 related, but cleaned my sisters headlights using a rag and toothpaste.
i like that shifter trim you did. did you use a plastic primer when you painted it? or just normal primer and paint
originally i lightly sanded the trim then hit it with satin black krylon fusion. then since i was sick of it. i lightly wet sanded with 400 grit and hit it with two coats of primer ( had some from when i painted my bike) then with 3 light coats of duplicolor wheel paint.
going to do the radio surround once the temperature outside stabilizes so i can go without heat controls for a day. then need to do the window control trim
why is everyone hating on the black UN-painted lip....
<fixed
because it ruins the lines on the front of the car.
and if there are no other supporting black accents, it just doesnt look right.
now on my car... it probably wouldnt matter :D
... i liked it on my car.... i think its the white grill that makes it look off... i had my grill painted black.... it doesnt look like his is unpainted...it looks gloss black... i guess im just trying to back up the other p5 panda...
and yes now i have my lip painted half white and black....
