AFC-SplitSecond PSC1 Map Library
This example shows how to set up Aux A to display AFR. In order to acquire the
reading, the orange/black wire is connected to the brown wire coming from the Innovate
Motorsports LC-1 Lambda Cable. The LC-1 generates a 0-5V output based on the AFR reading.
This output is pre-programmed so that 0V corresponds to an AFR of 7.35 and 5V corresponds to
an AFR of 22.39.
Connect wideband out, to input on AFC.
For the love of God. Something possessed me to tap into the brown wire on the ECU harness. Well I don't think it really affected anything other than hacking up the ECU for no reason. Now the best part is, I didn't hook up the wideband myself so where would I find the brown wire? By the gauge or by the 02 sensor?
do you have that wideband, or a different one? you need to connect whatever wire is outputting the signal of the wideband, it would come from the sensor, but if you have a gauge, you should be able to tap it anywhere in there.
I have the Prosport wideband. So you're saying I could just run the input wire from the AFC right over to the gauge without leaving the cabin? That would be nice.
I have a uego, its wire comes directly off the back into the ssafc, its not in the wires that go to the sensor.
Alright so I got the ECU out and I was looking at the connections on my wideband controller. The set of wires that go to the 02 sensor include a wire that to me looks like brown. I looked at the instructions that were included but it doesn't specify what each wire is for. Any ideas?
Here is the gauge I have..
http://prosportgauges.com/wideband-air-fuel-ratio-kit-Amber.aspx
Also just realized after ripping out the ECU that I'm still running the stocksupermap. I suppose I should change to the FMIC map now?
noob question... Do i have to hook up the IM vaccum to the vaccum line on my SSAFC? The line is very short so I would extend it, but i am just double checking.
well now that its finally warm again im getting 11.6 at wot. on the supermap.
im gonna try the fmic map next. see what ratios i get with that one
what do you shoot for for AFR at WOT? I thought we were looking for 13's. just got it in and it is running 13's on pulls and when i shift it drops to low 10's. If some one could check out my gragh and give some advice I would be very greatful. I took a pic of it.
<a href="http://s822.photobucket.com/albums/zz142/msp1337/?action=view&current=msppull.png" target="_blank"><img src="http://i822.photobucket.com/albums/zz142/msp1337/msppull.png" border="0" alt="Photobucket"></a>
