Wagonbacker9
- 2004 'Hoe
5. They're running off the shelf tunes because they're lazy and anything is better than stock
(like me! LOL)
(like me! LOL)
(like me! LOL)
I got a question hoping someone can answer. Why is it that everyone says to set the PWM mode to "Pressure 0 to 30 Psi/3 vdc FS". I understand the pressure part, but I assume the /3 vdc FS part is 3 volts for the maf. Why not put the it to "Pressure 0 to 30 Psi/5 vdc FS" since we have a 5v maf?
The reason I am asking this is that I am maxing out my MAF at 5psi, and from the data logs its when the Table A goes to 3v. Keep in mind that I have an NA ecu, and from what I have read it is calibrated different then the MSP ecu.
Idk but the mp3 ecu isn't just a na ecu, it has advanced timing, could this cause an issue?
I could be wrong, but I think it is actually beneficial for us to advance the timing.
Well every MP3 owner that went turbo has switched to the MSP ecu. I don't know the exact differences but quite simply the MSP ecu was meant for a turbo. The MP3 was not.
I am 99% sure that 440's are the largest injectors that the SS AFC can handle.
Incorrect, I am running 565 pinks.
you can't really datalog a narrow band O2, and the 4 wires on the AFC are for 4 different inputs.
what are you tapping into the ECU for though? if you have a wideband, that output gets plugged into the AFC's input, then you datalog through the AFC.
