NEMOC Random BS Thread
Cleaned out the garage this weekend...
And went for a hike! Peek-a-boo
Only issue I ever had with BEHR was that when it dried it was 'rubbery'. I learned real fast not to just scrape and pull any overage on door trim as it would literally pull the entire length down the trim...so I'd cut it with my utility knife. This was over 10yrs ago too....
We have used the Sherwin Williams Duration and it is better than BEHR but I fell it is overpriced for what it is. We paid more to have the easy clean-up (with kids and all) and even so, we've found that when we wipe the walls we are wiping paint away too.
I used Sherwin Williams Duration in my living room mainly because the color I chose required a "Deep Base" and that's the only kind it comes in.. whatever. The kind I got this time was SuperPaint. I opted to get that one because it was on sale and only $3 more than the cheapest paint they offer...
Jenn, it's most likely not the paint. Bathrooms are tough because there is a lot of moisture in the walls. Here's a good read. http://www.ehow.com/how-does_5576786_causes-interior-paint-bubble.html
This is a half bath... it sees very little excess moisture compared to the rest of the rooms on that level.
I just don't get it....
not bad.. now if only the 2 were out, I'd take one of those for a spin.. I'm not really interested in any new mazdas.
Moisture can come from all sources. You did mention there was a leak once right? Even if you can not feel it, it's in there.
Yeah, but that's the master bath.. and it leaks down to the ceiling right next to the front door...
I'm going to see if they can thin the paint AT THE STORE (that's for you Luke).
SuperPaint must not be very user friendly...
Hose was a little short.... Need another 25 feet.
At least one side was 'pressure' washed, I thought about rotating the car to get the other side, but opted against it.
