xDJ DUBx's 03.5 Pure White LX-T
Oh lawd! What have I done?!
bought the best thing youll ever spend money on, thats what!
its a ****** breeze to install, the directions should be on the website if u didnt get them
I have one sheet thats "mazdaspeed use and install instructions", another one thats "wire schematic mazda/ford 2.0 FS" and a 5 paged detailed packet on the ssafc, I should be good to go!
It was a deal I could not let pass, v2 ssafc, $200 and the dude came to my door and dropped it off. Woop woop! I'm extremely happy :D :D
At the moment, 8psi is the weather permits but as low as 6psi on hot days. Until I get a WB, it'll be just for reliability tuning but after I get a WB, I'll bump it up a bit, omgz! :D
noob question I know but where does the serial cable connect to the controller at? Its just a black box with the two harnesses coming out?
lolz, I bet you could get and extension and mount one on the case so it could easily be tuned while in the car...
yeah probably, cut a little hole for it, I already have two little extentions.
Well damn, I just looked over my comp, I don't have a 9 pin serial port, only a 15 pin port. s***. Could I buy an adapter of some kind or will I need to use a comp with a 9 pin?
depending on the connector in the ssafc, goto your local electronics store and ask for aether a: male DB9 to USB adapter or a female DB9 to USB adapter.
I looked on radio shack and there crazy expensive. Ide try FRY's if you got one close
Ya, that 15 pin on ur laptop is the output for connecting a monitor. The USB, however, is all about passing data :)
