Don't be pissin in my cheerios! Eh, when I get it tuned I'll dyno it too and we'll see
once the weather gets warmer im gonna dyno at 10 psi. expecting 210-220whp
Im going to drive the msp home and then install my new LED license plate lights!!!!! Should be some pics tonight.
Got em installed, Those things are so bright! Give me a few hours for pics!
Been trying to install my USB to Serial adapter cable for the past hour or so... sounds like my luck as of late. I don't understand why the **** everything has to be so difficult.
-The driver CD that came with it was shattered in the packaging. I did not touch it.
-Went to the website and found a driver (triple checked the model number)
-It detects the cable after installing the driver, but gives me a Code 10 (device cannot start)
Is it just telling me that the cable is useless until I plug it in to the car? **** it might as well go try now. Can't believe I've wasted this much time on a stupid cable.
edit: I kept the cable unplugged until the driver was installed, since that was the issue I had with the cable at my work.
what OS and brand of cable?
wait, its not working while not plugged in? try plugging it in and see if it work?
LOL Yeah well I lasted a year, didn't I? No power mods though - I'm definitely not willing to sacrifice the longevity of the engine. The AFC is simply to get the car running correctly and smoothly, not for power purposes. I know a couple of places around here that can do the tuning for me, but for the time being, I'll probably upload a map from someone who is running similar mods to me (Vibrant + CustomMSP SMIC)
Unless you have one of those "magic" MSPs that puts up numbers that no one else with the same setup can touch, you should not expect 200whp from a vibrant and upgraded smic. I have the vibrant, custom smic, weaponR intake, turbohoses hot and cold pipes, Boost Sciences RDV, new wastegate and vac lines, and am boosting at 7.5 to 8. I dyno'd at 176 on Corksport's dyno. Derrick did say, however, that the use of an SSAFC with a good tune might make another 10%, which would put me at just over 190. The better news is the torque which was also at 176, a better gain than the gain in whp. But the best news of all? The changes I've made can definitely be felt on the "butt dyno"... its readout says "Wheeeeeeeee!"
^^good deal man!
which rotor/pad combo do u guys suggest. Ive heard slotted is good. So im leaning toward Rotora rotors anf Hawk Hps pads.
^^good deal man!
~9 psi, CAI, 626 mani w/ thermal spacers, Turbohoses SMIC and DSM Convert hard pipes, Vibrant catless I got up to 213whp on a dynojet on a fairly hot slightly rainy day. Stock ECU.
You will need a touch more to get 200 with just Vibrant and SMIC. EM would be the biggest helper, as would catless. I noticed a pretty big gain when I removed mine.
